Posted By lzerarc on 14 Nov 2010 10:53 PM
I think I have convinced my wife to do a passive solar 'modern' house instead of a typical cookie cutter craftsman style that are being thrown up all around here. I can up with a few designs and modeled them in Revit so she could see that they do not have to be boxes with flat roofs. I dug out my old solar design book from college from when I studied under a renown solar designer to check my glass to mass ratios.
We both want a basement, so that will be a challenge getting a main mass collector via slab on grade and working the basement around it without introducing a steel structure. However we both love wood floors and really want them in the space. SO my thought is to try and get a collector source as a vertical wall instead of the floor. We want to use some sort of limestone on the exterior, so my thought was to clad the 4-6" thick concrete wall with a limestone veneer in the living room and make it more of a "feature" wall and disguise its real purpose. Digging through my book, I am assuming that the stone veneer will simply add additional mass and not alter the absorbing properties of the mass wall?
I currently have plans for a passive solar house with a basement and have not seen any issues with placing a 1-1/2" to 2" thin slab on the main floor. I.e. normal wooden floor joists.
