Suggestions to implement Sustainable building practices
Last Post 14 Jul 2011 02:28 PM by Chloe Taylor. 2 Replies.
Glass is GreenUser is Offline
08 Mar 2011 07:09 AM
1.Use a whole-building design approach to maximize resource-efficiency benefits through synergy.
2.Incorporate as many options from LEED.
3.Carefully plan construction and site design to preserve as much natural vegetation as possible.
4.Install high-quality insulation and double-pane.low windows.
5.Invest in energy-efficient and water-conserving appliances.
6.Use green roof or light colored roofing materials.
7.Carefully orient buildings to maximize the southern exposure.
8.Position the majority of windows on the south wall of buildings.
9.Shade windows to prevent direct sunlight in the summer while maximizing direct sunlight in the winter.
10.Consider the use of a geothermal heat pump.
11.Use floor plans that have main areas on the south side. Areas that are infrequently used on the north side. And garages and store rooms on the east and west ends of the building.
12.Plant shade trees on the east and west ends of the building.
13.Include thermal mass in buildings that will be used at night.
14.Incorporate a solar hot water heater in building design.
15.Each efficiency technique included in the design will lessen the heating and cooling load for the system.
Share your Opinions.
charlenejUser is Offline
20 Apr 2011 01:31 AM
All the pointers listed are indeed a great way to implement sustainable building practices. I agree that we should use green roof or light colored roofing materials as this allows the cool to remain even underneath the hot sun which in turn could keep the residents comfortable without having mechanical air-conditioning.
Chloe TaylorUser is Offline
Thanks a lot for sharing in the points i would be abiding by them when it comes to in installing an air conditioner....
<a href="http://www.capitalsteelbuildings.co.uk">Commercial Buildings for Sale</a>
People Online People Online: Visitors Visitors: 241 Members Members: 0 Total Total: 241
