Posted By Bob I on 12 Apr 2011 03:12 PM
detailing the exterior.
Thats one of the real advantages of a 1x3 "rain-screen" which you attach through the foam to the studs with long screws - you have a good solid surface to attach trim and possibly windows. I've used the technique on new & old buildings and have decided it is an excellent system. Easy to do, inexpensive and takes care of a what has been an ongoing long term problem - the deterioration of wood (and cement) siding. Allowing the back of the siding to dry out prolongs it's life and that of the paint finish. Vinyl doesn't need it, but I think it is preferable to a zillion nails perforating the foam.
Long-nailing the siding through foam is a LOUSY approach and something of a straw-man argument for kermit to make. Just because it's
possible
to do a hack job with exterior foam doesn't mean you
HAVE to do a hack
job with exterior foam.
IMHO rainscreens should be required by code for stick-built structures in the US just as they are in Canada (at least anywhere that gets more than 20" or annual rainfall, or more than 6000 heating degree days). It's a relatively low cost cure for a world of moisture loading ills. Rainscreens would be of advantage in Mooney Wall assemblies too- even more so than with the foam-clad approach. But in the foam-clad case, furring over foam to support the siding (furring long-screwed to the studs) is absolutely the right way to go.
The reason the lifespan of painted back-primed wood siding with 1x furring for a rainscreen is substantially longer than with wood siding applied directly to the felt/housewrap, or wood siding with no paint on the interior face due to the quicker drying, lower moisture content, and much reduced moisture cycling of the wood under the paint. The vapor-pressure of the moisture released from the wood from temperature cycling is orders of magnitude lower, minimizing flaking/bubbles/cracks. Being lighter than fiber-cement, it requires fewer fasteners for hanging the furring as well, but that's a pretty minor issue. I'm not the biggest fan of vinyl, but vinyl siding is inherently
back-ventilated, and doesn't need much depth to the rainscreen and is
light enough to be mounted on the thinnest of furring.
Up to about 3-4" of foam this approach is pretty easy, but for fatter rigid foam the screw lengths required for hanging the furring become a real PITA, and the moment-arm is long enough to require tighter spacing. Still, 4" of iso on an advanced-framing 2x6 24" o.c. cellulose-filled studwall comes in at ~R40 for a whole-wall R using a 15% framing factor. You can't quite get there with a Mooney Wall using mere 2x6 studs, even with 2x6 laterals (the rim joists and plates being the thermally bridging Achilles heels of a high-R Mooney Wall.) To hit real-world R values higher than ~R38-40 other approaches would be easier and more robust.
