I previously discussed some stuff regarding this house over
here since that post, I have read alot more and learned (I hope).
The house location is in Zone 3b (Hot-dry).
The house will be slab on grade. 5100 sq feet + 4 car attached garage. The house is 10' interior walls, so the exterior walls will be considerable square footage.
My current plan for the walls is 2x6 with blown cellulose. Structural engineering requires 1/2" plywood on all exterior walls. I would like to tape the plywood seams. I would then like to add 1" of foam on top of the shear wall. The foam on such a large project may be cost prohibitive - not sure yet. I need to figure out the exterior wall square footage and how much the foam is per square foot. Do I need a house wrap if I use the foam and it is taped at the seams? The exterior finish will be siding. Debating between the Hardie or some other brand of engineered type wood??
THe house will likely utilize at least 2 HVAC units. The HVAC equipment will be going in the attic. Still trying to figure out if there is any way to put it somewhere else. It may be possible to put one HVAC unit in the garage. However, it is likely the ductwork will all be run in the attic. The interior design of the house does not lend itself well to soffits in different areas. So, I am trying to plan based on the HVAC and ductwork being located in the vented attic.
My roof will be standing seam. I think hard foam below the standing seam (as suggested by DANA1 in the other post) will be cost prohibitive for the gains? I was going to a radiant barrier plywood, but I think DANA1 says it is a waste of money if you have a cool roof. I hope to use a cool roof (assuming we can get a color of our liking).
Attic - I plan on cellulose in the attic above the ceiling. We will likely have recessed lighting in a variety of places (I know not recommended - but in a house like this - it is almost mandatory). I have read about spraying foam above the ceiling. Is that economical in my situation? Does it get sprayed right over the can lights or do you have build boxes for each one? Since the ductwork is in the unconditioned attic, I suppose R8 is recommended for the ductwork. I have also read about burying the ductwork. I thought Los Angeles Building and Safety requires the ductwork to be suspended in the attic, but I will double check on that.
I am looking for an overall plan. I am looking for the perfect balance of energy efficiency, cost effectiveness, and aesthetics. I want my cake and eat it too.
