I am living in a 1971 "California split", a raised bungalow with a grade level living room at the front; 2x4 construction with poorly applied bat insulation in the walls (frost in the corners and floor to wall joint at -30). There is a total of 1100 sq ft in the home (upper floor and grade level living room (another 800 sq ft or so in the basement). I just had an energy audit with blower door and got a few surprises including...
-big time air infiltration through main floor pot lights, at exterior wall electrical plug boxes and around doors/windows.
-three inches of wood chips covered by 5 1/2 inches of fiberglass bats in the attic (R20ish according to the appraiser)
and
-major air leaking down the chimney of what was a wood burning fireplace in the L/R; it was capped and now has a gas fireplace (sealed unit with inlet/outlet air)
He also pointed out the brick wall (inside the house, from floor to vaulted ceiling (north wall of the L/R) either has very little or no insulation. It is also brick on the exterior rising to about 6 ft above the roof. In the winter I have to keep the gas fireplace on to keep that brick wall from cooling off the main floor. The brick is ice cold and cold air just sheds off of it.
I know to...
-increase insulation in the attic (code minimum is R50, I'll see if I can squeeze in R60),
-use foam gaskets behind the cover plates of the exterior wall switch/plug boxes,
-caulk and seal the windows the best I can
but have no idea what to do about that cold brick wall or how to seal the pot lights.
Ideas?
I am in Winnipeg, Canada. It gets darn cold here :)
edit; I tried to post a picture but its not working :( ........ figured it out!
