Posted By acwizard on 24 Nov 2011 01:20 PM
You may want to contact an engineer . Sound Transmission problems can be very difficult to resolve . Mechanical equipment operates with different frequencies. One method or product may only deaden a certain frequency. Your vertical shafts are acting like amplifiers.Ductwork should have offsets and can be constructed to absorb fan noise either from blower or the velocity of air moving within the ductwork.Noise attenuators may be necessary. Shaft enclosures should be constructed using sound board and multiple layers of drywall.
Thanks for your reply.
This is not my area of expertise unfortunately, but I have recognized that there is a problem worth addressing.
All the pumps have been removed from the ceiling mounts and any direct supporting rods have now been mechanically isolated.
You can actually feel the difference.
The biggest issue was always the floor penetrations and the ductwork in the mechanical room.
My insulating contractor has suggested spraying all the ductwork in the mech room with small fiber fiberglass/glue and doing the same thing on the ducts above the ceiling in the pool area itself.
I will ask an acoustic engineer to visit once all the equipment is fired up, to address the myriad of frequencies at play, then spray or use whatever may be needed to address that.
I agree with you that sound board and drywall will likely play a significant role here, Just wish someone had foreseen this issue a little earlier in the build, nonetheless, sometimes solving a problem on the fly can be rewarding intellectually, were it not so painful in the wallet area.
