Rollable Insulation
Last Post 01 Feb 2013 04:57 PM by Dana1. 1 Replies.
jpostumaUser is Offline
23 Jan 2013 08:56 PM
Has anyone ever come across a rollable insulation product? Hoping to find a flexible type of rubberized eps or something like that. It is for a tent application in remote exploration camps. We are currently using rolls of radiant barrier claiming to be insulation, but is there any type of 4'x30' rolls of thermal barrier out there? thanks.
From a performance per pound point of view packing the stuff in on human-mules you can cut 4' or 5' rolls of the reflectorized bubble-pack stuff. It's available in 48" or 60" rolls as long as 125', which would give you four 30-footers. (Reflectix is one vendor, there are others. Product numbers that start with "HVBP" are the bubble-pack type- See: http://www.reflectixinc.com/basepage.asp?Page=Double+Reflective+Insulation&pageIndex=622 )
It's performance is not really great- pretty useless in performance-building applications, but the air-tightness of tents isn't good enough to warrant a very high R-value. An R100 wind-tunnel isn't exactly going to outperform an R2 wind tunnel by very much on retaining heat. Bubble-pack beats single-layer radiant barrier on performance, but don't expect to get more than about R2 performance out of it unless you can trap air-films on both sides rather than having it in contact with the tent fabric.
If these are semi-permanent camps and you have mechanized transport, an inch of 1.5lb closed cell foam like FrothPak sprayed on the exterior of tents is very air tight R6-7, but you don't want to use it with gas-lamps or around open flames.
People Online People Online: Visitors Visitors: 202 Members Members: 0 Total Total: 202
