Roof
Last Post 28 Feb 2013 01:00 PM by Ed64. 2 Replies.
Ed64User is Offline
27 Feb 2013 11:26 PM
New construction home.  1/2 CDX on trusses, then Gaf Deck armor, then 2" rigid foam, then 1/2 cdx , then gaf deck armor and roof material.
My question:  I can get 2" rigid foam with black craft paper facing for a very good price.  With all the different foam facings foil, no-face, plastic, paper, etc.  What should I use, and what is the applications of different foam facing?
dave111User is Offline
28 Feb 2013 09:15 AM
Why two layers of Deck Armor? That stuff is kind of expensive. I'd also only use it if you have roofing material that breathes (top vent), seems wasted otherwise. I assume that you are doing insulation also against the bottom of the roof deck, I think folks here are going to need more information about your plans there.
Ed64User is Offline
So I have a vaulted ceiling and what is attic I will do conditioned and insulated.
I will lay some type of material over cdx. What I am really after is
what the rigid foam (iso) with black felt or craft paper is used for?
Thanks for the reply. Suggestions welcome.
People Online People Online: Visitors Visitors: 331 Members Members: 0 Total Total: 331
