This is great guys, this is exactly the type of discussion I wanted to start to see how far out of line I am thinking.
Liebler, I am in Port angeles at about 350' above sea level, and winter temps rarely drop below 20F. The 2X6 definitely isn't needed for structural, and you are absolutely correct it could be accomplished with spaced 2X4 and enough structure to support the inner drywall. The plan is a vapor barrier immediately outside the drywall completely encompassing the living space. If I did it right, my first cut at heat loss numbers tell me just shy of 4K BTU/HR with 65F inside temp and 30F outside temp. That calc is for still air and was done without accounting for skylights though and a very rough estimate of window/door area(havn't finalized window selection) and no accounting for air exchange losses.
The delay of transfer thru the ICF mass was making me think that the inner ICF skin will have difficulty getting below dew point in this climate. Is the figure for typical adults heat output around 500 BTU/HR? If so I am figuring at a minimum I will need to makup at least 3K BTU/HR, or a little under 1KW worth? Not quite a candle, but low enough to allow me to run a lower temp heat storage scheme(lower delta and less loss). It will also make future solar augmentation a little easier.
The overall loss numbers are why I have not planned on the ceiling being significantly greater insulated than around R74. I don't see the need to have the ceiling in this case significantly more insulated than the walls, especially in a radiant heated structure with lower overall room air temps. I will afterall not be pumping in 120F+ air from a furnace that immediatly heads for the ceiling to escape thru that insulation... We had originally looked into a dome home with a superwall construction of near R75 overall. Planning and positioning inside a dome was a very conflicted process and I was repeatedly having to compromise. So we kept the only thing i really liked, the superwall, and sought to incorporate that into a more conventional construction.
I see the concern with the radiant not hardly needing to run though. I guess this would allow me to increase the air exchange...
All input greatly appreciated
