Posted By jdebree on 29 Sep 2013 08:19 AM
I'm using a number of recessed LED cans (horrors!) I have a test model in my barn that stays on 24/7, and it is only slightly warm- you can barely feel it. Here in SC, the climate is so mild I don't think they will be an issue. Snow is rare, and melts in a matter of hours anyway. I used 'air-tight, insulation contact' cans, but they aren't very tight. It appears that the only real seal is the gasket on the bezel. I plan to built boxes out of foil-lined foam to go over each can to reduce the effect of thin spots in the insulation. Does anyone know if I can safely seal the cans themselves? There is a pretty big gap in places that could be sealed with aluminum tape. Or can you spray foam on them when the ceiling is flashed prior to cellulose?
In SC you don't have to worry about ice dams creating roof leaks that back up, soaking the wall's cavity insulation and causing staining/dripping through the gypsum, which is what I predict will happen if he sticks with R38s with thin-spots where the can lights go. (It's a slow motion movie with a predicable ending, it's been run SO many times before.)
The gaskets are kind of a joke, as is the air-tightness. Sealing the fixtures better with FSK tape works, and caulking the fixture to the gypsum with acoustic sealant or fire-stop 1-part foam works too. I wouldn't spray-foam the whole can though- in 25 years when it comes time to replace that LED that eventually failed a foamed-in-place fixture would be a nightmare to replace.
