Bump-out vapour barrier question
Last Post 06 Dec 2013 04:35 PM by robert.thompson. 2 Replies.
robert.thompsonUser is Offline
05 Dec 2013 02:11 PM
Hello:
My floor has an 18" x 60" extension beyond the foundation on which the zero clearance fireplace sits.
I am about to close off the bottom, on the outside, and wondered if I need to install VB on the warm side of all the cavities between the joists etc before I stuff the cavities with Roxul insulation.
Any info on this would be appreciated.
Rob.
Rob.
http://googlevoiceforcanadians.com/
FBBPUser is Offline
06 Dec 2013 10:36 AM
If you have continuous wood from top to bottom you will provide a place for warm air moisture to condensate so yes you would need v.b.
If you finish the outside with a layer of eps to provide a total thermal break and you detail the exterior as 100% air tight, then you would not need a v.b.
Thanks FBBP
Would 2" of eps under the floor (between the joists) plus 5.5" of Roxul between the joists and then cover the whole 18" x 60" opening with 2" eps (nailed to the bottom of the joists) and then cover with finishing be OK?
Would 2" of Polyfoam XPS do instead of eps?
Rob.
Rob.
People Online People Online: Visitors Visitors: 273 Members Members: 0 Total Total: 273
