Thinner basement slab
Last Post 28 Jun 2014 10:50 AM by smartwall. 6 Replies.
LieblerUser is Offline
20 Jun 2014 10:59 AM
Traditionally basement slabs are 3 1/2" thick but?  The makers of "Helix" have a parking lot that is only a 2" slab on EPS foam over grade and it has held up under several years of use.  It would seem that  a 2 1/2" slab of 4000 PSI concrete with 15#/yd of Helix over say 3" of type 1 EPS would be a fine basement floor.  Has anyone gotten an inspector's approval?  The saving in $ for less concrete more than pay for the Helix and I suspect the result has lower embodied energy so it's probably "greener".    Type 1 foam seems to be all that's needed as it has a 10 PSI compressive strength which when derated by 1/3 to prevent "creep" still comes out to 480 PSF while even 3 1/2" concrete @150 #/yd adds a dead load of 31PSF to the residential design floor loading of 40 PSF. giving a "safety factor of 6+.
20 Jun 2014 12:54 PM
I think that durability would depend on the soil underneath it - one example doesn't prove much for other cases (like expansive clay). Other techniques for concrete reduction are non-uniform thickness (use foam strips to create beams) and post tensioning (sometimes used for tennis courts). Or high strength concrete (up to 19,000 psi).
20 Jun 2014 05:13 PM
Posted By jonr on 20 Jun 2014 12:54 PM
In exactly the same way as plain concrete or otherwise reinforced concrete could suffer over poorly drained expansive soil.  The 2 1/2" slab I've described is in fact stronger than a 5" slab reinforced with minimal 6 x 6 mesh.
strategeryUser is Offline
24 Jun 2014 01:39 AM
You're losing some good quality mass in exchange for that lower embodied energy.
24 Jun 2014 09:45 AM
I wonder how much of the parking lot performance comes from the EPS preventing frost from penetrating (a frost protected design). And from a very well prepared base and/or a higher psi mix. "Stronger" is such a vague term when it comes to reinforced concrete performance.
TLPUser is Offline
26 Jun 2014 06:24 PM
Opps wrong thread sorry! :)
smartwallUser is Offline
I pour 3" with Helix
People Online People Online: Visitors Visitors: 201 Members Members: 0 Total Total: 201
