North Georgia SCIPS house
Last Post 02 Feb 2021 05:30 PM by voldie. 38 Replies.
GeorgiaTomUser is Offline
21 Dec 2014 08:13 PM
light embedment? sounds like a double row of inferior embedment
21 Dec 2014 08:21 PM
I expect that rain water will come down the walls and enter the inevitable crack between the footing and the stucco/wall. Standard rebar in this joint area might eventually rust no matter what the cover is.
21 Dec 2014 09:27 PM
SCIPs use either sprayed concrete or high PSI structural mortar to carry the loads.  Stucco can be used but only for a finish.  In this case, Carmelo structural mortar will be used to embed the rebar dowels and to cover the galvanized wire mesh.  Rebar can be countersunk back into the EPS to gain more embedment.  Waterproofing will also be applied.  The wall/footer joint will be below the bottom of the basement slab.  Locating the slab above the joint should allow it to brace the wall even if the rebar dowels do shear.
21 Dec 2014 09:44 PM
the rebar can be countersunk into EPS, not sure what value rebar into EPS has, but that's not what the picture showed anyway. There is no positive connection of the wall to the footing as far as I can determine.
21 Dec 2014 11:02 PM
Inside and outside rows of rebar dowels are located between the galvanized wire mesh and the corrugated EPS.  The location of the dowels are staggered on 16" centers.  Both rows of dowels are wired to the galvanized mesh.  Countersinking the dowels into the EPS requires EPS to be removed to create a void behind each dowel so that it can be filled with structural mortar.   Spraying structural mortar on the installed panels creates a bond with the wire mesh, dowels and EPS.  This creates a positive connection between the footer and panel.
rlsmith017User is Offline
22 Dec 2014 12:32 AM
I have been on the road and haven't had a chance to join the discussion. For those who may have not read the blog, Alton has been involved in the project since the very beginning and is very familiar with most of the details.
A couple of points to add:
1. The Carmelo mortar is rated at 4000 psi @ 28 days. Based on the EOR's experience I believe he said the long-term value is more like 7000 psi. This is a far different material than regular concrete, plaster or stucco.
2. A finish on concrete or mortar increases resistance to water penetration. Since the mortar can be finished all the way down to the footer we should avoid many problems associated with rough concrete in subsurface applications.
3. The mortar is the last line of defense against moisture. We designed to include a waterproof membrane which will overlap the fastfoot material and be glued to it. The mortar will be radiused from the vertical wall to the top of the footer, directing water away from the wall. The fill will be washed gravel with 1 foot of clay at the top. One of the advantages of the fastfoot system is that the drains can be lower than the top of the footer, rather than roughly at the same level like many applications.
4. The early pictures showed the rebar in contact with the EPS. After the panels are up but before the mortar is applied the EPS is burned out to provide room for the mortar to completely surround the rebar.
Hopefully this clears up a little of the confusion on the subject.
Roger
22 Dec 2014 10:39 AM
One additional question that I missed earlier: the entire exterior will be waterproofed, not just the below-grade portions. We are planning on using an elastomeric finish for the color and waterproofing above-grade.
Roger
23 Dec 2014 06:33 AM
still trying to wrap my head around a plaster coating inside and out having any structural capabilities - how is it bonded to the foam? since the foam is below grade is it treated against termites
23 Dec 2014 09:54 AM
See http://gulfconcretechnology.com/ind...gory_id=22     for mortar specs.
The panels as shipped are not treated to kill termites.  The high PSI structural mortar on both sides of the wall should deter termites.  No structural wood in wall for termites to eat.
See http://gulfconcretechnology.com/  for short video.
23 Dec 2014 10:03 AM
Although Alton is correct that there should be no termite danger we will treat for termites as if it were a wood house. I'm concerned about organic material around the foundation attracting termites so although there is VERY limited wood in the structure we will take the additional precautions.
Roger
23 Dec 2014 10:15 AM
GeorgiaTom:
I think this should answer your questions about the structural properties of the panels.
http://www.drjengineering.org/system/files/drj/ter/node/69/ter_1202_12asd_gct_insulated_concrete_panel_building_system.pdf
We are using the thickest panels, the PSM 240 panels.
Roger
23 Dec 2014 12:38 PM
I expect that underground will be damp enough for corrosion no matter what you do with finishes or membranes. Given the minimal increase in cost, I'd use epoxy coated rebar as cheap long-term corrosion insurance in a SCIP house.
23 Dec 2014 01:03 PM
Posted By jonr on 23 Dec 2014 12:38 PM
If you are talking about vapor diffusion and the permeability of how much water vapor will travel through the stem wall/basement wall, I would be interested to see the calcs on that.
If the ground is saturated with moisture, water vapor can still make its way through since EPS is permeable and its permeability is based on its thickness. That is why EPS sitting in a pool of water for days/weeks/months will take on water and begin to get become water saturated.
This will surely be climate dependent. In the desert southwest I wouldn't worry about it but in the humid southeast it would be more of a concern.
I reference Alcatraz again because the prison walls began to fall apart from the INSIDE out. The corroding rebar within the concrete mass wall caused the concrete to crumble. While this was an extreme environment (next to ocean with salt air 24/7), it served as a lesson when it comes to when epoxy/corrosion resistant rebar should be used.
23 Dec 2014 05:08 PM
Epoxy coated rebar can be compromised during installation.  Once the coating is scratched, corrosion can continue under the coated part.  Galvanized rebar might cost more but would not be as easily compromised as epoxy coated rebar.  Basalt rebar is stronger, lighter and not subject to corrosion.
I would not recommend epoxy coated rebar for this application since the wire mesh can scratch the coating.
Ideally, I would like to see the rebar dowels outside the mesh.  This would avoid having to raise the panel to slid it down over the dowels.  However, more mortar would be required but the labor savings might offset the extra cost of mortar.
23 Mar 2015 09:42 PM
There is a new post on the blog, updating progress through mid-December. It's only a little late. . .
http://northgeorgiascipshouse.blogspot.com
Roger
guyprotectionUser is Offline
23 Apr 2015 10:20 PM
thanks for the good info
23 Apr 2015 11:44 PM
Posted By rlsmith017 on 23 Mar 2015 09:42 PM
Thanks for the blog, very informative.
Would you say the total wall costs for everything came in at around $25 per square foot of wall space?
24 Apr 2015 07:46 AM
I've had a couple of inquiries about the cost of the wall system. It's still too early to see if I will meet the original estimate of $25 per square foot. The fact that the house is three levels (basement, main floor and loft, with poured concrete floors on all levels, may push that figure upward. Once the envelope is finished the builder and I will try to tease out the $/sf figure for the walls. Separating the cost of the SCIPS walls from the cost of the SCIPS roof may be a challenge.
We are still a couple of months from that point.
Roger
voldieUser is Offline
Bumping this thread. How did the project go? I am assuming that you must have been happily living in your house by now.
People Online People Online: Visitors Visitors: 321 Members Members: 0 Total Total: 321
