fasteners for 4" eps.
Last Post 04 Dec 2014 11:04 AM by jgeorgeiron. 3 Replies.
kenoraUser is Offline
03 Dec 2014 12:52 PM
I can get 6" construction screws (#10) for $63.70 per 1000... the next available size is 7" (#14) @ $500 per 1000 ... OUCH!! Is it RECOMMENDED or REQUIRED to have 6 1/2" screws for attaching 4" EPS to exterior wall with 1/2" furring strips.
03 Dec 2014 04:22 PM
They need to be pancake head timber screws or they'll split the furring, and yes, they're expensive, which is another reason to go with standard lightweight siding and 1x (3/4" ) furring, so you can keep the spacing at 24" o.c. .
You probably don't need 1000 of them (or do you?).  You can get boxes of 250 for about $125-150 from web-stores.
FMHLGM712-250 HeadLOK (= spider drive pancake head, 7.5" timber screw)
http://c.shld.net/rpx/i/s/pi/mp/21875/4552314727?src=http%3A%2F%2Fimages.factoryadvantage.com%2Fcatalog%2Fproducts%2F111%2F1113270078%2Flarge.jpg&d=4fb5cbecdebfedb2a448aca2bdd13f957b33ceee&hei=1000&wid=1000&op_sharpen=1
03 Dec 2014 06:07 PM
It isn't widely understood that you want to cause friction and force transfer between the furring, the foam and studs - the goal isn't to hang the siding off of a protruding lever. So glue would help and stud penetration depth isn't that critical. Of course there may be specs that require otherwise.
jgeorgeironUser is Offline
I did this on my home addition with these screws through 4" of polyiso... it worked awesome. My only note is that I did have some 1x3s laying around that I was trying to use, and they didn't work (they split too often). 1x4s worked great though - definitely the way to go. I also used a corrugated plastic venting material (Cora-vent) to provide a rainscreen channel (I am very happy with the result). I hung fiber cement siding to finish off the envelope.
People Online People Online: Visitors Visitors: 209 Members Members: 0 Total Total: 209
