Green/Energy-Efficient Building and Construction
Trim Innie Window
Last Post 25 Oct 2015 11:31 AM by
smartwall
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
agagent3
21 Oct 2015 11:10 AM
Are there any tips that someone would be willing to share on trimming out innie windows? I will be placing 1 1/2" EPS foam over the outside sheeting. I'm thinking about vinyl siding or maybe even steel siding applied horizontally. Is there any advantage to purchasing the windows with J channel? I'm looking for all good ideas. Thanks
ICFconstruction
24 Oct 2015 10:22 AM
The J channel does make it easier, especially if you are trimming with drywall. If using wood you have to use 1/2" thick, because I think that is what the J channel is. Otherwise lots of the long shims.
smartwall
If you get a window with J channel its part of the exterior nail flange. You can buy snap in drywall return for the inside if that is what you mean.
Membership:
croccohvacusa
People Online:
