Slope and lineal drain at time of pour
Last Post 13 Oct 2016 10:26 PM by Nashvegas. 5 Replies.
agagent3User is Offline
12 Aug 2016 03:47 PM
Is there any best practice with regards to installing a lineal drain at the time of pour? How do I put the slope in for a curbless 3' by 5' shower?
ronmarUser is Offline
14 Aug 2016 11:34 PM
Well if the CC guy is really good, he could probably shape it by hand if you are able to locate and orient the area properly around the drain, just like they typically would with a floor drain. YOu would of course have to plan out the vertical recess to allow for the tile work.
It might be easier to block out the area for the shower a little deeper than necessary with a wooden form and build-up/grout in the shower later to the desired height.
arkie6User is Offline
15 Aug 2016 06:45 AM
Posted By ronmar on 14 Aug 2016 11:34 PM
That is what I would recommend as well.
01 Sep 2016 04:46 PM
Posted By arkie6 on 15 Aug 2016 06:45 AM
Me too, it's done with a damp mixture of portland/ sand - dry packed and shaped with trowel
FBBPUser is Offline
12 Oct 2016 12:13 AM
http://www.schluter.com/schluter-us/en_US/Shower-System/Prefabricated-Substrates/Schluter%C2%AE-KERDI-SHOWER-ST/p/KERDI_SHOWER-ST
Much better
NashvegasUser is Offline
I quit using mud pans several years ago and switched to Shuter or A knockoff - Prosource. Also use the membranes on the walls instead of mud. More expensive, but a huge timesaver.
People Online People Online: Visitors Visitors: 222 Members Members: 0 Total Total: 222
