BlakeJ
| 26 Aug 2017 06:59 AM |
For central Texas, what would be the best way to insulate second story interior walls that are next to uninsulated attic spaces? I have blown in cellulose in the floors of the attics already, so I'd rather not go through the effort of removing the cellulose and insulating the attic ceilings. Thanks! |
icfbound
| 27 Aug 2017 12:58 AM |
I think people will be better able to provide you with suggestions if you provide more details like size of wall cavity, will you have exterior foam, etc. |
CONservative: The first three letters are all you need to know to fully understand this Republican. <br /> <br /> Racist: A person who believes their race is superior to another race. <br /> <br /> Religion: The deception of suckers who fear nonexistence to believe in a nonexistent supreme being and to adhere to false doctrine to control and exploit them. <br /> <br /> Republican: A greedy, racist, sexist person who skillfully uses deception, hate, fear and religion to control and exploit suckers to gain personal wealth and power to benefit themselves while using government to limit the freedoms, safety and pursuit of happiness of others. <br /> <br /> Sexist: A person who assaults, discriminates, intimidates or stereotypes the opposite sex. <br /> <br /> Sucker: A weak minded person who has been brain washed and who usually lacks education and critical thinking skills allowing them to be easily deceived. <a href="https://www.youtube.com/watch?v=vGAqYNFQdZ4">Watch...Don't Be a Sucker!</a> <br /> <br /> Trumpian: A narcissistic and skilled con artist Republican who is highly attractive to suckers and uses Fascist and Nazi tactics and commits traitorous acts to undermine democracy to gain personal wealth and power. |
BlakeJ
| 27 Aug 2017 01:01 AM |
Just normal 2x4 construction. The walls haven't been built yet, they are bonus room additions going in. So I'm open to any construction/insulation ideas. |
Dilettante
| 27 Aug 2017 02:04 AM |
So let me see if I have this right. Your second story is, essentially, an uninsulated attic space at this point. You have BIC on the floor but no insulation anywhere else. You're basically looking to carve out a room (or rooms) from this space. Honestly, your best bet is to just insulate the roof/ceiling of the entire space. Otherwise the room will see heat gain from the roof deck. You don't need to remove the BIC. Just make sure the space is properly ventilated. Then it doesn't really matter what you put into the walls of the room itself. Indeed, you could go with something more for acoustical insulation than thermal. |
BlakeJ
| 27 Aug 2017 03:45 AM |
Yeah basically let's just say you're building a bonus room in an uninsulated attic. The attic itself will be insanely hot most of the time in the Texas summers, even if you insulated the roof deck. There's gonna be some serious heat loss through the walls, I was just wondering what would be the best way to insulate the walls. Thanks. |
arkie6
| 27 Aug 2017 05:38 PM |
1" foil faced polyiso foam board (RMax R-Matte Plus 3 - made in Dallas, TX) on the outside of the studs with the foil facing out toward the attic, HVAC duct foil tape all joints, then damp sprayed cellulose in the stud cavities. |
thescottcav
| 27 Aug 2017 09:40 PM |
Do you have the possibility to maximize your ventilation in the attic? If you figure out your maximum lower vent area in the soffits then you can figure out how much additional venting can be added for your ridge vent or whatever vent type you have in your roof. Our 2nd floor interior attic walls are 2x4 framed and sheathed with 2" EPS foam/OSB/r-13 batts. |
BlakeJ
| 28 Aug 2017 02:00 AM |
The roof has a full length ridge vent, and soffits. Basically 2:1 length ratio, soffit:ridge vent |
