Sikasil ws295 what can I use ot for?
Last Post 02 Aug 2018 10:42 PM by toddm. 3 Replies.
kenoraUser is Offline
02 Aug 2018 04:03 PM
I have an opportunity to buy sikasil ws295.. white in the 600 ml sausage packs for $2 a sausage. That's an amazing deal but I'm not sure where to use it... Ideas... plz I can buy about 300 sausages if need be. I'm building next spring Thanks
toddmUser is Offline
02 Aug 2018 05:48 PM
I've used Sika products twice, neither of which was ws295, in situations requiring extreme flexibility. Sikaflex is a caulk for steel roofing, which is subject to considerable expansion and contraction. The second, Sikabond, is a glue for hardwood flooring, also formulated to handle movement. Sikaflex was the go-to caulk for my roofers, and its floor glue was one of three recommended by Warmboard for adhering hardwood over radiant. The product sheet for ws295 lists glass-to-glass and window uses as well as masonry sealing, and it also discusses movement.
https://can.sika.com/content/dam/Canada/Main/01_General/PUB_Documents/SikasilBrochE_fpo.pdf I'm guessing this is silicone with extra stretch. I don't know why it wouldn't substitute for GE Silicone II in general caulking.
02 Aug 2018 06:52 PM
Would it be a good replacement for construction adhesive.. thanks
Construction adhesives are polyurethanes, as is sikabond flooring glue. Sikasil is a silicone. Try technical support at 800-933-sika
People Online People Online: Visitors Visitors: 234 Members Members: 0 Total Total: 234
