FLash, Bat, Flash the roof deck
Last Post 12 Aug 2019 06:31 AM by Dilettante. 1 Replies.
KeithwwUser is Offline
31 Jul 2019 02:35 AM
I'm building a ICF house with a conditioned attic.  I'm thinking about doing a flash and bat for my attic roof deck 2 inches of closed cell foam, rockwool, then using spray foam to hold the rock wool in place and to cover the rafters to reduce thermal bridging and to hold the rockwool in to place.  Not a full coating, just the seams to hold it in place.
Any reason not to do to this?   I would encapsulate the studs then add the rockwool, but am worried that the added width would make it to difficult to pack the bats into the space remaining.
DilettanteUser is Offline
Okay, had to reread this. Missed that you're not ACTUALLY encapsulating the Rockwool, as that MIGHT lead to condensation issues.
This seems like a needlessly complicated method to securing the batts.
On properly spaced rafters, your batts should fight snugly enough that they don't immediately fall out.
And if you're really worried about thermal bridging, add a layer of sheet insulation to the exterior of the roof.
Boom! Thermal bridging managed!
