Posted By A W Warn on 11 Aug 2019 05:09 PM
When I have built buildings with similar situations, I installed a waterproof membrane barrier between the sheathing and insulation, front, back, and top of wall. The WB must be self healing, so that the mechanical fasteners holding on the insulation will not let water pass through (similar to WR Grace Perm-A-Barrier). The water barrier terminates at a through wall flashing that directs any water out of the wall.
ps: Asphaltic membranes have a tendency to creep out at the through wall flashing when encountering extremely high temperatures. Another type of membrane may be more appropriate in your area.
