Chain Saw Depth Guage
Last Post 28 Feb 2007 03:38 PM by Terry Hackbart. 10 Replies.
DaveJackson6User is Offline
18 Jan 2007 10:56 AM
I am looking for a recommendation for where to buy a universal chain saw depth guage.  I understand these are made, but do not know the manufacturer and distributor.  I have a Ryobi chainsaw that I would like a depth guage for routing electrical chases.  Any help would be appreciated.  Thanks!
Dave Jackson<br>Fox Blocks - The Clever ICF<br>[email protected]
jDeBroUser is Offline
18 Jan 2007 12:35 PM
Dave,
I have been reading these forums for a long time now and thought that maybe it is time to contribute...
I have been an ICF builder for almost 5 years.
I have been using a 10" cordless Ryobi chainsaw, which was the smallest I could find at the time. I made up my own simple depth gauge using a few misc parts found at any hardware store. It all cost about $5 and it took me less than five minutes to put together.
Take a look at: http://www.debrohomes.com/icfsaw.jpg
Works great, allows me to roll the saw along the wall.
Let me know if you have any questions.
If you haven't come across it yet, check out http://www.icfelectrical.com. I haven't used them yet, but intend to on my next project,  hopefully I will be able to totally eliminate the chainsaw snowstorm!
Joe DeBrosky<br>www.debrohomes.com
Mark FlemingUser is Offline
18 Jan 2007 08:07 PM
That's a nice looking depth gauge.  I've got the Ryobi battery powered tools and was thinking about buying the chain saw for just that purpose.  I assume that the depth gauge can be easily removed and you've got your original function back.  I have seen a C-clamp used, but I never felt very comfortable with the way it looked.  Now if you'd only design a dust collection system for it that hooked up to a shop vac.
My one experience with routing conduit inside the ICF form was not good.  It has to be water-tight, otherwise when using a high slump some of the fines can leak into the conduit.  The only way to avoid that would mean gluing every connection.  It doesn't take very much concrete to solidify and make pulling wires impossible.  The loss of time and materials makes me sceptical of using such an internal conduit system unless it was really, really, really necessary.
Mark Fleming
icfblocksUser is Offline
18 Jan 2007 09:42 PM
Dave,
WinLock used to sell a depth gauge for a chain saw.  Don't know if they still do but it's worth a look.
SLCUser is Offline
20 Jan 2007 04:19 PM
Hi Joe,
What would be approx measurement from the end of the chain/bar to the edge of the rollers?
Tks
Sly
20 Jan 2007 04:41 PM
Sly,
It is approx 2 1/4" to the end of the bar. The cut depth will vary a little though based on the angle that you are holding the saw. It's not always easy or practical to cut holding the saw perpendicular to the wall...
SLCUser is Offline
22 Jan 2007 06:36 PM
Hi Joe, Excellent that's the info I was looking for. Understood re:perpendicular position. Tks Sly
walltechUser is Offline
22 Jan 2007 08:02 PM
Just take a standard Black and Decker chain saw or equivilent $45.00 saw from the H-depo and drill a hole 1/4" 2" from tip of chain threw center of bar. Take a 2" x 3/16" all thread bolt with 4 nuts on it first all the way to bolt head insert threw hole add 3 more nuts with a 4th locknut. This will ga. the depth. Works great! Some customers claim they like the saw a little dull though and just hold the saw as flat to the wall as possible and let it hit the concrete. It makes for a wider slot and they seem to have no issues with it.
Dave
tseymour33User is Offline
09 Feb 2007 12:08 AM
I used a remington electric chain saw and found that sliding closet door rollers worked perfectly when bolted through the hole near the tip of the chainsaw.
James EggertUser is Offline
09 Feb 2007 08:40 AM
What a great variation on the chainsaw setup!!!
Terry HackbartUser is Offline
I have used their electrical parts on 5 or 6 foundations and the work great.
Terry Hackbart
People Online People Online: Visitors Visitors: 149 Members Members: 0 Total Total: 149
