Foam degrading over time
Last Post 27 Jan 2007 10:26 AM by James Eggert. 5 Replies.
stormmountainUser is Offline
25 Jan 2007 02:05 AM
Wanted to hear if anyone has had experience with foam degrading or pulling away from concrete over time? Would be interested in any long term duration studies of ICF construction or personal experiences of living in an ICF for over 10 years?  We are considering building an ICF in the mountan west of the U.S. where summers can be very hot and winters can be very cold.  A traditional architect has mentioned to us that foams don't all hold up over time in our enviroment (he has focused on commercial development for the past 35 years).
jDeBroUser is Offline
25 Jan 2007 06:31 AM
I don't think there is any more chance of the foam separating from the concrete, as there is from the plywood sheathing separating from wood studs.
With embedded webs every 8" and a concrete key "keystones" along the interior of the blocks it all gets held together with enormous strength.
The few times I had to make changes to a wall (don’t ask) was a testament to the strength of the system.
Joe DeBrosky<br>www.debrohomes.com
DallasBillUser is Offline
25 Jan 2007 11:01 AM
Perhaps you should ask the traditional architect how the foam is holding up in his refridgerator, which is subject to hot/cold and moisture, just like the foam in an ICF home.
He would then have to answer "It NEVER sees it, because it is covered on both sides" and then he would have to stop with the scare tactics.
icfblocksUser is Offline
25 Jan 2007 08:56 PM
I know that ICf's have been around for at least 25 years. I researched some patents on Foam Form about 12 to 14 years ago and they went back over 20 years then. They were manufacturing in Arizona Foam Form then and a friend of mine bought some molds and molding equipment to mold them with. If there has ever been separation of foam from the concrete in an ICF it is certainly a great secrete. Anyone interested in some used equipment to mold with call me. It's been in storage for at least 10 years. It's to bad that some architect's as well as some others are so opposed to change.
vhehnUser is Offline
26 Jan 2007 06:24 PM
all foam manufacturers will tell you to not allow foam to have direct sunlight. it will degrade.
James EggertUser is Offline
That's right, the UV degradation causes the "dust" on the EPS surface which needs to be cleaned off depending on the siding material used. Id siding over, I wouldn't bother, but when using any cementitious or Acrylic parging or base coat, then the foam needs to be at a minimum broomed off before attaching the mesh, or applying the parge-coat.
People Online People Online: Visitors Visitors: 148 Members Members: 0 Total Total: 148
