Posted By yogia on 03/24/2007 11:25 AM
Hi jc:
The referenced Graph is viewable. However, your reference report on the ORNL site comes up with a "Not Found" error.
The original link has been fixed.
There have been practical studies where they built similar ICF and stick-built houses and determined the energy savings using ICF to be significant.
I have not seen these studies. And, obviously, they would conflict with the ORNL studies.
What is your position on energy savings in residential construction in building with ICF and SIPs over stick-built construction?
The main difference would be their(SIPS & ICF's) ability to reduce/eliminate air infiltraction. The others would be lack of thermal breaks and R-Value.
Now, one can use conventional materials to construct a wall with superior insulative qualities:
...and what do you think of the differences in the referenced ORNL study and the real-world whole house studies?
I would need to see the 'real world' studies, and definitely who sponsored them!.
The key to thermal performance is primarily
R-Value, R-Value and R-Value. However, all of the R-Value in the world can be rendered useless with a high rate of air infiltration. So, while I consider R-Value the most important element of a thermal envelope, low air infiltration and reduction of thermal breaks are also very important.
