fturkdal
| 06 Apr 2007 04:52 PM |
hello,
I am mid size ICf contractor, and I have good size ICF project w/ Brick ledge for all exterior walls. I will need lots of ledge stirups. ( My manual stirup bender is too much work) I am planning to by power cutter bender. What is do you know about them? if you were buying what will you buy.
Frank |
PatrickT
| 06 Apr 2007 06:06 PM |
fturkdal,
What kind do you have now? |
fturkdal
| 06 Apr 2007 07:38 PM |
Manual ( shear typ. w/ musle powered) cutter/bender. also manual stirup bender purchased from wind-lock.
Frank |
irnivek
| 06 Apr 2007 09:12 PM |
We have an EZ Bend for bigger bar (#5 and #6) We use an Hitachi VB16y for the #3 stirrups when we forget to order them in time from the local concrete supply house. They make and deliver each stirrup for about $0.40 Kevin |
icfcontractor
| 07 Apr 2007 07:50 PM |
Fturkdal,
Look at the Rod Chomper. It seems to work well.
ICF Contractor |
icfblocks
| 07 Apr 2007 08:14 PM |
We use a Hitchie VB16Y for all our needs. Am going to buy a Benner- Newman for cutting larger bar. If I am cutting a whole lot of bar the same length I use a cutoff saw. |
| Thanks,<br>Tom<br>www.advbuildingtech.com |
Chris DeLucchi
| 08 Apr 2007 10:52 AM |
I got an EZ-Bend that handles up to #6 grade 60. My engineer likes it because the bend radius actually meets code compared to most manual benders with too small.
fturkdal
| 10 Apr 2007 04:22 PM |
Thanks for all the inputs. I am having problem getting my brick ledge stirrups prebend. I request quote from one of my supplier and ihave not heard from them ( 700 pcs. may be too little) I callled and got price from one bigger co. and their price is $ 1.95 ea. + tax and shipping. I still think I should by the power cutter bender. Question is which one. I like one has tool kit for diffrent dies for diffrent diameters.
Hitachi VB16Y looks good. Can you fabricate all stirrups about same dimension? Frank |
Chris Johnson
| 10 Apr 2007 06:18 PM |
Frank;
Using a VB16Y is convenient, but the hook is large and leaves very little clearance from the foam on the brick ledge, I recommend using the old fashion manual bender, the hook is tighter and keeps adequete clearance for concrete. As suggested earlier, use a quick cut saw to cut all your lengths, make a template stirup then just start bending, you'll be done in no time.
Chris
ContractorPete
| 10 Apr 2007 11:44 PM |
We have 2 vb16y's, I believe that you can change the size of the die on the bender to get the desired radius for the stirrup. Since you can bend 2 pieces of steel at the same time with the hitachi I just use a 'template' stirrup to build the rest by placing the template on top of the next piece i am bending. |
| [email protected]<br> |
fturkdal
| 11 Apr 2007 09:10 AM |
Hi pcoughlin, When you bend your stirrups is it one man or two man operation. Trying to figure out how easy to use.. is VB16y rated for continues use? I can't find any info on their dies. Where do you get them.
Frank |
ContractorPete
| 11 Apr 2007 11:49 PM |
Sorry I thought you could change the die size on the vb16y but after some searching I dont think you can. However I have not had a problem with the stock die that the unit comes with in terms of having a radius that is too big for any 6" icf application. When making your own stirrups it is definitly a one man operation. What I do to make a stirrup is figure out the stirrup size I need according to the lintel size and spec of the corresponding horizontal rebars and then determine a inner top to bottom measurement for my stirrup. After determining the correct size (so that you get your clearances for your inner horizontals top and bottom) I make a template and then cut and bend the required amount. Heres an example of a lintel over a 16' garage door on my current project:   |
fturkdal
| 12 Apr 2007 12:09 PM |
Nice picture,
Looks great. Like Chris mentioned hooks may be to big for brick ledge stirrups.
Frank |
irnivek
| 13 Apr 2007 05:38 AM |
I checked, actually we have the Hitachi vb13y for the stirrups. $500.00 new on ebay....
Kevin |
fturkdal
| 13 Apr 2007 12:15 PM |
Kevin,
I could not find vb13y on ebay or web. no one has listed price. if i can get for $ 500.00 from ebay it is well worth it. does hooks small enough for brick ledge (amvic) stirrups.
thanks
Frank |
