Gas Appliances
Last Post 22 May 2007 08:38 AM by
James Eggert
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
bonzai95
18 May 2007 10:42 PM
Has anyone had (or heard of) any issues with using Gas Appliances in a very tight ICF house? I know you need an air exchanger, just wonding if a gas water heater and range would cause any issues.
JOhn
Chris Johnson
19 May 2007 12:49 AM
No, there are no issues with any gas appliances as long as they are installed properly and vented properly, ICF houses are very tight but you still have to open and close the door to enter and exit the house, there is both kitchen and bath fans in the house and yes the air exchanger is a great idea regardless.
James Eggert
21 May 2007 07:51 AM
I suggest you use a direct vent WH to eliminate that issue.
As to other appliances, it depends on useage; typically a range should not cause problems, but, one area that may is the exhaust hood for the stove/cooktop. There are ways to provide make-up air which eliminates the pressure problems a 500. 750, 900 cfm blower can cause.
bonzai95
21 May 2007 11:16 AM
We are planning on having a downdraft range.
My real concern was we were considering a gas powered tankless water heater. The HVAC guy I was talking with said there wan't enough air exchange in the house to handle that.
john
James Eggert
They are also available in the direct vent version....and they work very well.
We used a 6.2g model for a two story 3+ bedroom home, and the owners are delighted!
Membership:
croccohvacusa
People Online:
