If your distance is minimal from finish grade to start of siding, say under 12" than using an acrylic stucco base coat works well, Dryvit (US) or Durock (Canada) are a couple of manufacturers I have used over the years, you need to purchase the base coat only, it is grey in colour generally as well as fibremesh, fibremesh is available in a few thichness I recommend the thickest one since the area is vulnerable to damage (lawnmovers, weedeaters, etc) trowel on a thin layer and apply mesh by embedding it into the base coat, continue around the building when you get back to the starting point if it is set up enough start the second coat every 20-25' return to where you left off and either use a sponge or a hard plastic float trowel to create a clean consistant finsh. Don't try this yourself the first time, have someone helping you, and if you make a mess, put another top coat on and work on the finish again. When you all said and done no one will even know you have an ICF home unless they see the depth of the windows/doors.
Chris
PS - I usually run the parging a couple of inches over the waterproofing installed below if it applies |
