Cantilever or build straight up?
Last Post 17 Jun 2007 12:27 PM by
bjherron
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
harrisb
16 Jun 2007 04:40 PM
I am in the design phase of my home and am looking for suggestions to keep costs down. The home I am designing will be ICF construction ranch style with a full basement. My question revolves around gables. At the front of the home there are 3 gables which will jut out approximately 5 feet each. There will be a concrete floor system with hydronic radiant heat and I am building in a climate where temperatures vary from -30f to 95f. I am trying to determine if it would be more cost effective to build a square basement and cantilever those gables or just build straight up with ICF.
There will be several factors in play here, engineering costs, material costs and keep in mind I will be stacking my own ICF's.
Opinions are much appreciated. Thanks.
Brad
harrisb
16 Jun 2007 04:42 PM
For a visual the front facing wall will be similar to this:
|____|--------|______|
walltech
16 Jun 2007 08:07 PM
Brad, is your lot a walk-out?
Dave
harrisb
17 Jun 2007 10:22 AM
No, it is a flat lot with no walk out.
bjherron
My basement is far from square (10 outside corners, 6 inside corners). I faced the same decision, but decided to go straight up with ICF. It increased my basement size, and most ICF contractors bid on the wall square footage, not the design anyways. It made the floor system and load bearing points a bit more complicated, but overall I think it was more cost effective to go the way I did.
Membership:
croccohvacusa
People Online:
