ICF room over ICF garage
Last Post 25 Jul 2007 06:09 AM by ICF372. 4 Replies.
OronoUser is Offline
22 Jul 2007 06:57 PM
I am having an ICF house desgined at the moment and am planning to use either speedfloor or Hambro. It will include 2 floors and a walkout basement. The designer just got done drawing up the first floor and is working on the second.
The first floor has a 27*27 garage and the master bedroom(22*22) will be right over it. The designer is insisting that since I will be using concrete floors, the exterior walls of the master bedroom don't have to sit on the ICF walls below and only 1 wall is alligned with the wall below.
Now I know that it's something that can be accomplished but will require structural engineering and will add more cost to the project.
Am I right in my thinking or what he is saying can be accomplished easily.
James EggertUser is Offline
22 Jul 2007 09:14 PM
Engineering can accomplish your offset walls!
Its your decision if you want to expand the budget to accept this aesthetic feature!
Basically, it is going to be a design element versus an owner desire. The owner desire is I want the feature....I will pay for the feature!
Simple economics!
icfcontractorUser is Offline
23 Jul 2007 07:22 AM
to add to Jim's accessment,
I am currently doing a project where several ICF walls do not allign witht the wall below. This is being accomplished with a cast in place floor system from Logix and intregrating several cast in place beams. I would be suspect of the bar joist systems because they are not a 100% concrete floor. You are relying the steel web truss joists as you tension portion of your floor. It probably can be done with a bar joist but the normal loading on a floor of this style is less than 100 psf for the floor, live, and dead loads. I think the design exceedes that dramatically.
ICF Contractor
PatrickTUser is Offline
23 Jul 2007 07:58 AM
Run your plans past Hambro to see what it will take. They have been good working with us.
Patrick T.
ICF372User is Offline
We are about to start  4 Town House's where the walls do not line up. The trick is to design the upper icf as the structural beam. You also could set the speed floor joist at a closer spacing in that area only. And yes you will need a structrual engineer.
Eldon Howe<br>Howe Construction
<br><br>Total Concrete Homes provide positive cash flow , DAY ONE .
