Posted By Cattail Bill on 01/12/2008 8:01 AM
On the bottom we install a 3 1/2" discharge hose where the garage door will be meeting the floor, the floor is poured
up to it on one side and the apron on the other side, this acts as our expansion joint as well as our thermal break,
and door seal. Make sure you radius the edges at the hose when doing this so you have no sharp edges.
I'm not so sure about this idea, as the hose would fill with water and get skunky. Fill it with flexible closed-cell
foam, OK. But there's still the problem of the concrete breaking over the hose at the thinner points.
The blue-board idea is good, although the top surface would damage easily.
dmaceld, I think he means water-pump discharge hose, which is rubber, fairly stiff, with a non-corregated surface.
