using cement block with icf
Last Post 02 Feb 2008 08:02 PM by walltech. 5 Replies.
aksmith42User is Offline
24 Jan 2008 11:03 PM
Hi everyone I've got some more questions for you.
Like I said in another topic  I'm planning on doing my own icf basement this spring.  My house will be a one story ranch style home with a 9 ft. basement and an attached three car garage.  I was thinking about laying cement block for the garage, and tie it in to the icfs.  Will this work?  And if it will what's the best way to tie them together, maybe just stub rebar out of the icfs and attach the blocks to this.  Also is pea gravel for the aggregrate poured in icfs common?  ive heard of installers using it.  All your help and opinions are greatly appreciated.
Adam
25 Jan 2008 12:04 AM
Pea gravel is fine for up to 8" forms, above that I use 3/4" or a blend of both
DO NOT ATTACH the CMU's to the ICF unless your engineer tells you to, you want to waterproof the ICF 100%+ and this won't be 100% possible with the CMU, keep it away 1 - 1 1/2". If it must be joined, do it on the top course only...above grade...if the engineer accepts that.
Chris
walltechUser is Offline
25 Jan 2008 07:46 AM
Chris, and Ak: We have this scenario quite often. Once the ICF wall is stacked we place a vertical piece of peel and stick at but location from the footer to top of ICF. We then stack the garage lead walls with either ICF or dry-stack cmu to support garage footing at higher level. Then the walls and stem walls are poured and back-filled. As the masons stack the garage cmu they drill and dowel into the ICF threw the P&S, keeping in mind that this wall will have fill on both sides and doesn't need much for dowels. We then roll our dimple out on the cmu a foot or so and seal edges.
Just another option and I haven't seen one leek this way yet.
Dave
Cattail BillUser is Offline
02 Feb 2008 09:58 AM
I like to look into the future and for the little extra cost maybe $150.00 I just use icf on the garage frost as well.
In Minnesota our clients get asked will you ever use this in the cold months to work on something, the answer is always yes so why not have an insulated foundation, and again the answer is yes!
02 Feb 2008 07:06 PM
Posted By Cattail Bill on 02/02/2008 9:58 AM
I'm doing my entire garage with ICF, including the wall between the garage and kitchen. With R-15 garage doors it shouldn't take much heat to make it into a cozy shop, and even with no heat will keep the cars warm!
Actually the cars will keep the garage warm. Between my wife's 300 and my f350 on a 20* evening the vehicles raise the garage temp to almost 50* just from our drives home.
Dave
People Online People Online: Visitors Visitors: 204 Members Members: 0 Total Total: 204
