Use of 4" Spacers
Last Post 07 Feb 2008 09:41 PM by Chris Johnson. 2 Replies.
FarmboyUser is Offline
07 Feb 2008 11:24 AM
Has anyone used the 4" spacers to reach a specific height?  If so, any problems?  Would you use them again?   Since they come as a 4" tall strip without ties, I would place them between the two full blocks at the top of the wall to minimize concrete pressure and attach add'l bracing.  Thoughts?
icfblocksUser is Offline
07 Feb 2008 08:30 PM
Have used them to reach spafic heights as well as to reach spacific sill heights on windows.  To reach a wall heith they do work well between two full blocks or pannels.  One of the companies does make a tie to go with the height adjusters. Depending on the block you might need to strap or tape the joint.
Evalute the cost and they by themselves look expensive, if the math works and you can use a H/A and a 1/2 block or less to reach the top it makes sense, plus the waste factor was just cut down down signifigantly. If you need to use two rows of H/A the math doesn't work on cost of product but you can save on waste.
People Online People Online: Visitors Visitors: 292 Members Members: 0 Total Total: 292
