Footing Size
Last Post 17 Mar 2008 07:51 PM by
bkvanbek
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
p2a3w4e5
06 Mar 2008 06:50 PM
Question. What should be the footing size for our soon to be house. The house will be 2 story with full basement in Wisconsin. Soil(psf) is 2000. ICF is 6" for all levels.
Thank you all for answers!
P2
Paul Stevens
06 Mar 2008 08:47 PM
When I build a 2 story with full basement all ICF I build 8"x24" footings with 2 runs of 15m bar(#5 I think). This usually works for me all the time in Ontario. I would imagine the local building dept. can let you know the size regarding your soil conditions.
Don Regan
07 Mar 2008 06:42 AM
Who is building your house in WI?
Don Regan
07 Mar 2008 06:43 AM
What brand ICF are you using?
Farmboy
07 Mar 2008 02:18 PM
Most block makers include footing width tables in their engineering guides. These tables are usually based on the Prescriptive Method for ICFs in Residential Construction, Ed 2 or the International Residential Code. Two 6.25" blocks I looked at showed 20" and 21" wide footings for a two story above grade ICF home on 2000 psf soil. And this includes the foundation walls. Refer to the tables for the block your considering. As I learned this gets you in the ballpark, but if any question about your soil strength, consult an engineer or your local building inspector. Dave
bkvanbek
20" x 8" or 10" thick if you use dowel pins.
Membership:
croccohvacusa
People Online:
