Cleaning Chalk Powder On Foam, ICF
Last Post 24 Mar 2008 07:49 PM by Chris Johnson. 2 Replies.
WayToGoUser is Offline
24 Mar 2008 05:12 PM
The windows need the window wrap around the window and there is a chalk powder residue on ICF blocks.
Want to know the specific and process, on what you use for cleaning the chalky powder left from the UV solar rays of the sun that is found on the Insulated Concrete Foam (ICF) after the ICF have been  set for some time?
Paul StevensUser is Offline
24 Mar 2008 06:07 PM
You should be able to just rub it with a broom head or towel and it will come off. You could also try giving it a wash with a bucket of 'soapy suds' and brush, when it dries it should be fine.
or
Use a UGGH rasp available from your local architectural coatings supplier
People Online People Online: Visitors Visitors: 455 Members Members: 0 Total Total: 455
