If you ask 10 different people which ICF is the best you will usually get 10 different responses. All block has its pro's and con's.
I install Block A 90% of the time simply because of the service I get from my distributor. If I need block on Monday it is usually dropped off on Sunday. You just can't beat that!!
If you are going to install yourself you need to buy from whoever can service you the best, Tech. Support, bracing, will be 2 major things that you will need. Which of the manufacturers you have looked at are close by with all the 'tools' needed for you to do the job. Don't always look at price to be the determining factor. Ask them for names of other DIY'ers whose jobs they have been involved in and them ask those people how the service was.
Personally, I stay away from blocks that have to be put together 'on site' (ones that have individual panels and a box of webs).
Logix, Nudura, Amvic, Build Block, Arxx, to name a few are all good blocks, and at the end of the day whichever one you use will give you the same result, an ICF home, workshop etc, it's getting to the end that matters.
Paul
Chris Johnson is an installer in the area and I am sure he wouldn't mind if you gave him a call, he should know all the local guys and will give you some ideas.
I imagine he will post soon enough any way.
You can reach him at
[email protected]
