ICF - Ireland
Last Post 29 Apr 2008 10:50 AM by tb1472000. 10 Replies.
cmaUser is Offline
01 Apr 2008 01:17 PM
Hi all,
Just came across this forum so apologies if my question has been asked previously.
I am currently at the planning stages of my first home and hope to use ICF for the exterior walls. This is due to a number of reasons including air tightness/low U-Value/sound, etc, and that i will be able to able to erect the system myself thus cutting out the cost of labour on site. {I was a foreman over a site of 10 houses which used ICF}
Currently there are a number of companies in Ireland with a franchise for ICF systems - Nudura / Reward / Amvic etc.  These are supplying 8" and 6" ICF blocks with only one choice in EPS width of about 2.5" [65mm]. I am interested in having a greater width of EPS panel perhaps 4" [100mm]. So I would be looking for an EPS block with 4" EPS - 8" concrete - 2.5" EPS. This is to up my wall U-Value to achieve PassivHaus standard.
I am interested to know the supply only cost per sq.ft of any system you may know of, but especially the likes of Nudura as I can make a direct cost comparison. Due to the sub prime debacle [ hope things bounce back cos we need big US industry too!!!] the dollar is pretty weak against the euro [1 euro  -$1.57 today] so if I can cut out the middle man in Ireland and ship direct from the US it would be great. [East Coast of the US - New York/Mass/Rhode island/ Conn etc]
If you could also just mention the spec of the ICF – EPS thickness etc.
Thanks & Kind regards
CMA
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
01 Apr 2008 08:11 PM
Unfortunately in the west here all ICF's (except one, I am aware of) have EPS at equal thicknesses on both the interior and exterior. I have surfed the web looking at European ICF's and did notice that the exterior has a thick EPS.
Go on the column on the left and you will see the various sponsors, one has what you are looking for, but keep in mind you are required to assemble the blocks on site.
As for Canadian/US costs on products each distributor sets his own pricing for his customers. I believe all of the blocks you mention have a local distributor to you, one does for sure.
Mark RossUser is Offline
01 Apr 2008 08:41 PM
try ISORAST, it will pass the tests, working on starting one in a couple of months our selfs in south central Ireland.
cmaUser is Offline
02 Apr 2008 11:02 AM
chris,
i realise most of the suppliers i mentioned have a distributor local to me, however many of these are just importing the product from an overseas manufacturer and adding their profit margin to the product. I am trying to cut out this 'middle man' and go direct to a usa distributer or usa manufacturer.
renangleUser is Offline
02 Apr 2008 11:28 AM
CMA,
I would try to contact Rory Ahern, of Terra Construction he is doing a massive ICF building in either Ireland or Scotland. He would probably be of assistance. Last I knew his project is 100,000+ sq.ft. His contact information is [email protected], hopefully he doesn't mind me posting this!
Ren Angle
adi43dUser is Offline
02 Apr 2008 04:09 PM
Look for Beco WALLFORM. They are from UK. I think they have a isorast licence.
take care
Adi
http://torontonetzerohouse.blogspot.com/
rardresUser is Offline
03 Apr 2008 03:16 PM
CMA,
Reddi Form, like the other ICFs you mentioned, does not offer EPS thicker than 2.5" but we do offer local production of our 6" core ICF and a solid product. If interested you can learn more about our ICF@ www.reddiform.com or you may contact me directly: [email protected]
Good luck with your project.
Ron Ardres
Reddi Form, Inc.
walltechUser is Offline
04 Apr 2008 09:01 AM
Build Block has ICF production in progress in Ireland and they are using 3" foam if my memory serves me correctly. Go to their web-site and find the Ireland manufacture and see if they are in production yet.
Dave
andruzzoUser is Offline
17 Apr 2008 01:51 AM
Consider Integraspec Ire., They are setting up local manufacturing, and the buzz is that they will have the capacity to provide a thicker exterior panel for our Scandinavian friends .
eric monkmanUser is Offline
27 Apr 2008 02:10 PM
Varianthaus makes what you are looking for.
BruceUser is Offline
QuadLock makes two size panels.  One is 2.25 and the other 4.25 inches thick.   They can be mixed in any combination to create R22, R32, or R40 walls.   You can see them at www.quadlock.com.
Another option would be to use windlock screws to add additional foam to any foam form.  This might actually be a cheaper option if the labor rate isn't too bad.  Also, Nudura makes something called ceiling technology with furring strips built in that might work well in a siding application if you need addtional connection points.
