superior alignment systems
Last Post 17 Jul 2008 10:32 PM by TLC-ICF. 4 Replies.
bbicfUser is Offline
15 Jul 2008 11:44 PM
does any one use or have used or know something about superior alignment systems,  I am just researching new braces and this is one I had seen , just a little worried about its strength, also the giraffe bracing system I have seen was wondering about them as well.  I have gone to my local aryxx rep (rona) they seem well recommended but they are going for 220 a pop which is a little more than I can afford right now, these seem a little more cost effective. any other suggestions are appreciated
Thanks N
FlaICFUser is Offline
16 Jul 2008 07:13 AM
Have had very good luck with Superior. Brace is easy to use, no extra parts, light for handling and easy to transport. Bracing does not have to be bulky or heavy in residential or light commercial work.
16 Jul 2008 09:38 AM
Thanks, how is it's strenght, I was a little worried about that as it is only 12 gauage steel and the other seeem to be made of more than that.  is there any trouble with the strongbacks bending etc.
N
SoCalScottUser is Offline
16 Jul 2008 11:33 PM
I have seen the Giraffe, Reechcraft, and Arxx bracing and all work very well. Depending on your location, you might be able to look for some "used" bracing if you don't need a lot, 40-50 sets or so. I know of a couple of guys in California that invested in bracing, but have gone in other directions with their companies after only doing a couple of projects. The only drawback would be that, if down the road you decide to purchase more bracing, you would have to purchase the same brand so that they line up.
I have not seen in person Superior Alignment System, so cannot vouch for it either way.
Good Luck!
TLC-ICFUser is Offline
just bought two units of Giraffe, seem to be a good brace.
People Online People Online: Visitors Visitors: 374 Members Members: 0 Total Total: 374
