This is somewhat simple, but the one thing I would suggest is make sure you hang the door from the side of the wall into which the door will open. That is, if the door will open from the house into the garage, then mount the door flush with the garage side of the ICF wall. Or vice-versa. This will eliminate the posssibility of the hinges binding or of the door not being able to open completely without hitting the wall. Its also easier to apply jamb extensions, if door swing is not an issue. |
