Tyvek Footings
Last Post 15 Aug 2008 12:45 PM by Chris Johnson. 3 Replies.
Boontucky-girlUser is Offline
14 Aug 2008 03:21 PM
On another thread I was told that Tyvek is perfectly fine to be used instead of fast-foot for DIY monolithic ICF with footings. One question that I have is this: Is Tyvek a moisture barrier that will keep water from wicking into the concrete? If it isn't, could I use just some cheap plastic sheathing on the outside of the Tyvek and that would make my footing waterproof? I guess my concern is if moisture gets trapped behing the tyvek. I plan on having perf pipe for drainage around the footings.
14 Aug 2008 04:35 PM
I have used tyvek on footings many times without an incidents or reprecussions. When I peel the footing boards off the tyvek lays down and the ground. I'm going to take a wild guess and say you could use plastic, issue being is strength, tyvek won't tear under the weight/pressure from the concrete being placed, plastic will over stretch or tear, not defeating the purpose 100%, but not as good as tyvek.
15 Aug 2008 08:31 AM
I guess I wasn't very clear on what I'm doing. But I plan on following this method here http://www.fab-form.com/products/fastfoot/mono-pour_menzel.html only instead of fast-foot I am going to use tyvek.
Fast-foot stays in place after construction and is supposed to be a wicking barrier between the concrete and the soil. I think this sounds nice, and I am just wondering if Tyvek will do the same thing and prevent moisture from wicking into the concrete if left in place. If not, if I wrap the footing with plastic, then wrap the plastic with tyvek, can I accomplish the same thing? Tyvek to hold the concrete pressure, plastic to keep moisture out of the footing concrete.
Thanks for you help!
Tyvek will keep the moisture out
People Online People Online: Visitors Visitors: 403 Members Members: 0 Total Total: 403
