Wicking and Moisture in Walls
Last Post 26 Aug 2008 08:11 AM by icfcontractor. 1 Replies.
VermonterUser is Offline
25 Aug 2008 10:01 PM
What prevents an ICF building from wicking moisture from the foundation up into the walls? I realize that the foundation should have protection against moisture, but what if it fails?
If moisture does get into the walls of an ICF building, how does it get out? With the EPS on both sides it seems like it would be trapped.
icfcontractorUser is Offline
Vermonter,
The foam is not a vapor barrier. Any concrete below grade is exposed to 100% relative humidity in the soil. Properly consolidated concrete that is over 5000 psi is considered impervious to water according to the ACI and PCA. I like to add Flyash and Slag to my concrete, they reduce the capillary effect that can occur. There are other additives you can put right in the concrete mix that "water proof" or "damp proof" your concrete. But the truth be told unless you are building in a total swamp, with standing water on you footings all the time, chance of an issue is remote. I build in a part of the country that gets rain 9 months out of the year and we have springs, seeps, and swamps everywhere.
ICF Contractor
People Online People Online: Visitors Visitors: 220 Members Members: 0 Total Total: 220
