18" thick grade beam.
Last Post 17 Nov 2008 09:55 PM by arkie6. 5 Replies.
17 Nov 2008 08:47 PM
I am bidding on a grade beam 4' tall and 1'6" thick on helical anchors and lots of rebar, horizontal and stirrups. Among the usual benefits I would need to insulate it after concrete placement this winter.
I don't know of any ICFs with a 18" core, does anyone? or other ideas to make it easier?
17 Nov 2008 09:09 PM
18" core can be achieved with either Eco Block or Nudura, you need loose panels, clips (webs) and joiners, available from both companies.
Word of advice....bring it up slow, like maybe 12-16" per lift or diaphragm the hell out of it with 1 1/8 ply and threaded rod
rgbUser is Offline
17 Nov 2008 09:18 PM
Integra Spec is also a possibility.
rgb
17 Nov 2008 09:30 PM
Formtech and PolyPro claim to be able to also, I can not find any illustrations. Did you find any details? Which do you think would work best/ stronger? Nudura would be less desirable because the 18" height does not come out to 4'.
17 Nov 2008 09:51 PM
For Nudura you rip the top block in half and use a height adjuster, wahlaa, 4' wall
You realize no matter whose block you use you are fabricating your own corner blocks
arkie6User is Offline
According to Lite-Form's FAQ, "Forming ties are currently available to produce concrete walls 4", 6", 8", 10", 12", 16", 18" and 24" thick."  And the XPS insulation planks are 2" thick, 8" tall, and 8' long, so forming a 4' tall wall/beam is easy.
People Online People Online: Visitors Visitors: 412 Members Members: 0 Total Total: 412
