How do you build a good base from which you can benefit year round? What if you could use the base as a transitional form of energy storage? Store the energy and retrieve when needed? Do you think this is possible? How would you go about forming an energy loop that would feed the base with energy and retrieve it at the same time?
Manfred,
To address your original question/concept, the basic fundamentals of heat storage/transfer(thermodynamics) are the most important to learn about and keep in mind. I suggest research into
passive solar heat storage, starting with the classic
The Passive Solar Energy Book 1979 by Ed Mazria. It is old, but the physical laws of heat storage and transfer do not change, and this is a great book for your purposes.
That said, I will try to paraphrase(BRIEFLY!?!?) some things I have learned over the past 20 years of building/using passive solar mass storage in homes.
1. There is
always a heat transfer occurring whenever there is a difference in temp. otherwise known as "delta T." between the heated material and some colder material. If you put pex tubing into the ground under the slab and heat up the whole of the slab and ground under it, you will indeed create a very large mass that is warmer than normal(50 or 55 degF ground temp). This will take quite some time and create a large warm mass that will take a long time to cool down. BUT...this heat in the mass will ALWAYS be being transferred to the colder parts of the ground on the perimeter of your "heated" mass since there is a delta T. This heat loss will be
very significant and will prevent the heated mass from achieving a high temp. that you want so you can "retrieve" heat at some later time. It will also cost a lot of money if you are not using solar/wind/geo/etc. to generate the heat for the liquid in the pex tubing. Your general idea is very good, it is merely lacking one major component: insulation.
2. A much more efficient way to store the heat in the slab is to place a layer of, for example, 2" Dow board insulation somewhere under the slab. By "somewhere under the slab" I mean that you could place some earth material that has a high heat storage capacity(you say you like the idea of sand, but you might research other materials in Mazria's book as well) on top of the insulation in a thickness of...2 to 12 inches or more, depending on a lot of factors that are too lengthy to discuss now. What you will achieve is a significant mass of slab and earth that is now very well insulated from the "cold" ground below the Dow board and outside your ICF foundation walls. I would also recommend putting the pex in the slab since that is closest to where you need the heat. The delta T between the heated slab and the sand under it will insure that the sand will become heated as well.
3.
IF you do as described in #2 above, you will have a very stable, warm mass that will provide very comfortable and CHEAP heated living space, BUT it will still not be a viable reservoir of excess heat that you described in your original post. To do that you would need the water tank that was also discussed, or some other storage medium that would most likely have a VERY long payback time and not be economical. Money is best spent on insulation so that the heat that is generated is transferred as slowly as possible to the cold exterior surroundings. All discussions of efficient heating will start and end with the insulation! I am soon to build my own ICF passive solar house and am contemplating using some extra Dow board insulation on the exterior of the ICF that will be below grade to better hold the heat inside, as well as under the slab.
Whew, what a babble...not very brief?!
Where are you located Manfred? Perhaps you should consider passive solar heating for the house as well as the radiant floor heat pex. I am very willing to discuss further any of these principles with you, but phone conversations are much more efficient. Call me if you wish: 307 290 0364. I live in NE Wyoming.
Hope this helps!
Dave
