Masonry Fireplace
Last Post 16 Dec 2008 03:02 PM by
jmagill
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
GuyB
16 Dec 2008 01:53 PM
How does a masonry fireplace in ICF construction differ from std stick built construction?
Is the firebox and chimney typically placed inside or outside the ICF structure? Is all of the foam removed between the wall and the flue chase to make it fireproof?
Manfred
16 Dec 2008 02:20 PM
there are different possibillities to approach this: You can build an ICF wall around the chimney structure and remove the inside portion of foam after the pour. Or you can stop the ICF wall just short of where the fireplace and chimney starts. The latter is cheaper. A open fireplace structure in itself is a big hole to the outside and therefore provides no energy efficiency when not in use. It is actually exactly the opposite, it will drain energy out of your house - in the winter and in the summer!
jmagill
Build the entire thing inside the ICF walls. You should have venting for air intake.
Membership:
croccohvacusa
People Online:
