ureaformaldehyde could be a problem. osb sheathing roof sheathing. is your entire home icf? natural gas emmissions coming through the ground? There are areas that this is quite common. Sulfur, menthane, and radon are just few that can cause health risks .
Chip,
Thanks for the reply. I don't know anything about OSB subfloor. I was told it was blue (?) subfloor which is a little better than the normal plywood. Yes, we have ICF for the entire home. We do not use natural gas. If you meant radon (as natural gas), we have installed radon system.
I need to google on menthane and sulfur. We have heat pump. It is sooooo loud.
Bruce,
Good point about work place toxins. My program was cut due to bad economy, so I am working in a new building starting Jan 20. So we will see. What really confused me was my X-ray in Jan 2007 was normal and we moved to our new house in July 2007, after a few months, I started to cough and to have sinus problems. My Jan 2008 X-ray started to show inflammation. Now, Jan 2009, it progressed pretty fast.
Both of my pulmonary specialists believe it might be environmental.
Thanks again for all these helpful tips and advice. Really appreciated them very much.
