My plans alreadey call and are passed for a garage grade beam on piles with a frost cushion, That is pretty standard here in Saskatchewan for the garage grade beam. So basically all I was thinking was that I would just do the exact thing but instead of having someone come in with their wood forms and stripping them later, I would just use my extra ICF forms to build the frost wall. I would still use the frost cushion to prevent frost under areas without. I just wanted to see if that was something I could do or not. I will look around for the shallow wall detail.
Thanks Nathan
