stucco over ICF
Last Post 23 Feb 2009 05:34 PM by wes. 15 Replies.
optimaxUser is Offline
03 Feb 2009 06:05 PM
We are ready to apply the exterior stucco to our new ICF home. We have narrowed the search down to two stucco masons.  Problem is , they have differing views on one thing.  One says that stucco over ICF doesn't need the underlaying lath, the other says he won't do the job unless there's lath underneath.  ( this also creates a $9000 price difference). Both are adamant about their opinions. Can anyone offer any advice as to whether or not the lath is truly necessary on ICF ( Amvic)
walltechUser is Offline
03 Feb 2009 06:17 PM
It sounds like your talking about two different systems. EIFS would be a synthetic stucco sytem that would not require lath (galv. steel mesh) as it is dirrectly applied to the ICF with a fiber cloth mesh. A non synthetic stucco (cement based) would require a metal lath to my knowledge but would not be the norm in todays world. Let us know what type of Stuco you ar using.
Dave
Marc&KemUser is Offline
03 Feb 2009 06:47 PM
Let me know too
Marc and Kemella
04 Feb 2009 06:10 AM
Thanks for the prompt response.
I intend on using a synthetic stucco.  That being the case, I see that you're saying that I would not need a lath mesh.
nkentUser is Offline
17 Feb 2009 09:47 PM
I have a question and didn't know exactly where to post it. My house is constructed of ICFs and part of the upper construction is with OSB board. I was told that I would need to put felt and lath on the OSB section before putting the brown coat on but over the ICFs, I would not need felt. Now I am told that some regional inspectors want felt over both the OSB and over the ICF's. It all depends on who I get as an inspector, I am told. What is really the correct way to proceed?
Another question: Can I put the stucco undercoat on the OSB and then an acrylic finish over that but put two coats of the acrylic finish over the ICFs?
17 Feb 2009 10:33 PM
If you put the felt on the ICF you cannot get into any trouble with the inspector. Technically you really don't need it, but every area is different. In my area you need it. Cost is inexpensive, put it on.
Don't mix conventional 3 part stucco on the framed wall with acrylic stucco on the ICF...it will be noticeable.
18 Feb 2009 07:24 AM
Chris, do you put felt *and* lath over ICF, or just felt?
18 Feb 2009 11:59 PM
You need lathe, cement basecoat needs something to adhere to and hold it together
19 Feb 2009 12:38 PM
Posted By Chris Johnson on 02/18/2009 11:59 PM
Chris, yes that's what I thought, but you just said felt in your post so I was curious.  Wow, that really adds a lot of unnecessary work and expense. But the code is the code, I guess. Must be frustrating.
19 Feb 2009 12:59 PM
Do you use Tapcon screws into the concrete to hold the mesh and felt to the ICF?  Do you use the diamond mesh that has black paper already attached?
19 Feb 2009 08:50 PM
I only show up when it's underway...I'm the ICF guy, not the stucco guy.
I do see the paper tacked with anything, usually roofing nails through the foam, diamond lathe screwed on with Grabber screws to the webs.
Kelly MooreUser is Offline
20 Feb 2009 10:34 PM
I would suggest that you look at a new product that passed the large missle impact test in Fl with a thickness of only as thick as a nickel.  What I would do with a ICF is apply a 2" thick foam(eps 1.5# density) that has a finish like brick, stucco or wood siding then a 2 man crew sprays a 2000 sq house in less than 2 days...
I also use it for the roof, no shingles or "S" tile to ever replace...  It is like srink wrapping the whole house...
No joints or seams and 100% waterproof...
All you need to do is paint it to any color or faux paint it.
Kelly Moore
561.309.2420
22 Feb 2009 11:26 PM
Kelly, maybe you could give us a name for the product?
22 Feb 2009 11:40 PM
IT is not on the market yet, it is owned by a huge chemical company.  They should allow me to realise it soon, they have not given it a final name yet.  Please be patient it is going to be the next big thing in the construction business...
Kelly Moore
561.309.2420
23 Feb 2009 08:09 AM
Kelly,
Please keep me informed about your new building system.  Here is my e-mail address:
alton at auburn dot edu       Replace the "at" with the @ symbol and "dot" with a period.
Kelly,
Is this the same product you were talking up on this forum a year or so ago?
Still trying to get it on the market?
How about some more specifics.
People Online People Online: Visitors Visitors: 222 Members Members: 0 Total Total: 222
