Pitched Insulated Concrete Roof Taboos!
Last Post 23 Mar 2022 04:51 PM by insuldeckflorida. 60 Replies.
Page 2 of 4 << < 1234 > >>
Raul HinojosaUser is Offline
10 Feb 2009 02:25 AM
Robincc..I think you will enjoy this.
Regards,
Raul
Attachment: 2.JPG
Attachment: 3.JPG
Attachment: 4.JPG
CFL-ICFUser is Offline
10 Feb 2009 07:41 AM
on the Orlando home. do you know why or what happened to make them switch blocks between the first and second floor???
Bruce FreyUser is Offline
10 Feb 2009 01:18 PM
I really like the roof system!
Do you extend the insulated panels over the walls for the eaves?
Can you show a connection detail (or picture) of how the roof to ICF wall connection works?  I assume there must be "concrete to concrete" bearing.  Is a section of styrofoam removed between the channels?
On the flat roof picture (which is what I am interested in) was there a parapet or an overhang?  How would you do a parapet wall with a flat roof on an ICF wall system?  A separate operation after the slab pour?
Bruce
10 Feb 2009 03:16 PM
Bruce,
   In most cases because architectural details or shape, an overhang formwork is used to form and pour the overhang. The overhang can be flat soffit of inclined as per architect desire. Also can be extended the panel if you may want it but like you said, at the wall intersection the foam have to be interrupted and the channel will continue. The only thing is that most architect do not want big thick facias.
   I am not sure what are you refering of overhang or parapet wall, but in a flat roof will be a separate pour for the parapet.
   This is a detail of the ICF wall parapet with the system on the roof.
Regards,
Raul
Attachment: Parapet ICF Detail.JPG
10 Feb 2009 09:36 PM
Raul,
Please send me the WRCS detail for a flat roof that you posted.  Attach the file and send to:
alton at auburn dot edu            Be sure to use the @ symbol and period instead of "at" and "dot".
I can read files in various formats:  Chief Architect, AutoCAD and Adobe - jpg, pdf, pcx ...
334 329-0957
10 Feb 2009 09:59 PM
Thanks rhino for the pics!
11 Feb 2009 02:07 AM
Posted By rhinojosa46 on 02/10/2009 3:16 PM
Bruce,
One of the pictures you posted had what looked like a flat roof.  I was wondering if it had a parapet wall  or whether the roof extended over the wall (cantilever or overhang).
Thanks for the detail.  It is how I envisioned it.
Also, how big is the space between the top of the insulation and top leg of the channel?  I assume this fills with concrete and locks them into the slab so there is no danger of the forms falling.  Do you calculate any composite structural benefit from this or is it primarily a safety issue?
Bruce
11 Feb 2009 07:39 AM
Bruce,
   Those Pics are a second floor. The walls above are the second floor walls that will support the WRCS concrete roof on top.
   The space between the top of the insulation and the leg is about 1 1/2", and yes, it is all filled with concrete to prevent any kind of falling due to interior ceiling installation. For the roof the channel is not considered as a structural component of the assembly (WRCS provides de engineering for the roof in tridimensional finite element analysis, and the shoring calculations and drawings), although provides additional moment resistance between walls and ridges.
   For the floors and flat roof you can be considered or not depend of the span, varying the gage of the channel and of course adding special devices to transfer the shear to the channel and increase the composite action, but basically the channel is for hold the insulation and act as a formwork system during the pour and later stay in place to provide a rigid surface ready to install anything you want.
Regards,
Raul
11 Feb 2009 08:13 AM
Alton,
   I sent you an information package already.
Regards,
Raul
ContractorPeteUser is Offline
11 Feb 2009 02:44 PM
How much shoring had to be done to pour that roof? Did you do the roof pour in one day?
[email protected]<br>
11 Feb 2009 03:34 PM
Pcoughlin,
This kind of roof use a typical shoring grid, probably 6' x 7" between post shores or mason towers with aluminum joist between post shores to support the panels. Yes, the roof get pour in one day, flat or inclined. Depending of the size of the job could be from 8 to 14 finishers douring the pour. Just to give you an idea, 10,000 sq. ft of inclined roof (around 200 yards of concrete) can be pour in one day with two pumps and 18 finishers in 6 hours.
Regards,
Raul
11 Feb 2009 04:07 PM
Raul,
Thank you.  I received the info.
12 Feb 2009 06:14 PM
what about this roof folks...
Attachment: kadir-final (1).jpg
ICF372User is Offline
20 Feb 2009 12:18 PM
Concrete roofs certainly complete the ICF structure.
Great advancements with the systems that were not available just a few years ago.
The downside of the system showcased is the lack of insulation on the top side of the concrete. In the end this may be a minor issue. A cold roof in Th North or hot roof in the South just is not the best we can do.
The system we use is simply a composite floor joist ( you pick the Manufacture) used as a rafter. We then insert  a standard Knock down ICF form ( you pick the manufacture).
The main advantage to this system is
1. no shoring is required at all.
2. insulation on the top and bottom side of the roof
3. the roof is poured in one day with only one certified technician and a couple labors
4. sheathing or tile can be attached to the plastic ICF studs and over hangs are easily attached conventionally
5. One pump truck with the use of 1.5" to 2" internal viberaters.
I cant seem to load up my large photos.
So I can e-mail them to you or you could the slideshow directly from Integraspec
Eldon Howe
Eldon Howe<br>Howe Construction
<br><br>Total Concrete Homes provide positive cash flow , DAY ONE .
21 Feb 2009 08:38 AM
That sound like a good system. But, how about pitched roof, certainly will use beams along ridge and valleys to support that system if you want to use it in a pitched mode. Down here in sound florida some one tried to do pitched roof that way (using Hambro or another kind of composite joist system) and was very expensive because he have to use beams along ridges and valleys and columns to support it in the middle because is not a system that can be self supported due to the one way load carrier nature.
About the insulation, remember that EPS perform better in cold climates. If you may need more just increase the foam density up to 3 pounds per cubic foot, I am sure that this will exceed you expectation.
Regards,
Raul,
21 Feb 2009 11:08 AM
I'm sure most concrete roofs will be more expensive, that's all relative to what you purchase.
As far as support. Support is support, whether it is red steel , shoring, ICF center beam or a cast in place monolithic concrete beam poured at the same time as the roof.
The latter is how we poured a 3 story community center here in Michigan, main floor, Mezzene and roof beams and floors/roof all monolithic.
We have a freeze thaw cycle that is very hard on concrete so it is best to keep the crete sandwiched between the foam.
I actually like the your system, I just wish it was covered in foam.
21 Feb 2009 11:38 AM
All things being equal, I prefer to keep the structure warm (especially in a flat roof situation), but as long as it is dry, thermal expansion/contraction should not be a structural issue.  Thermal expansion/contraction consideration may be needed in interior finishes that are directly attached to the roof in order to avoid cracking.
Having interior roof insulation is probably a bit better for minimizing thermal bridging.
This is really not much different than spraying foam on the underside of your roof trusses.
Raul's system offers a lot of flexibility and does things that other systems do not do.  Every design involves compromises!
Bruce
24 Feb 2009 05:02 PM
I'll try to add a photo.
I don't believe exposing anything to the elements is a good idea. Having said that, I'll not say any more about having exposed concrete.
Attachment: Interga Roof 40 man hours and 2 days experiance 01
24 Feb 2009 10:46 PM
Eldon.....is that a residential or commercial? Interesting to see steel rafters! Also, what is that on the roof.......foam of some kind?
25 Feb 2009 07:13 AM
That looks an even more complicated roof system, therefore more expensive. Appear to be 2" of eps sandwiching 2 or 3" of concrete, am I correct?. Below 12" Galvanized Channels bearing in the middle on a Steel beam. I don't know where you get the idea that the wrcs system is an exposed concrete. After that you will have to add either peel-n-stick waterproofing membrane (btw rated over 180+ mph over concrete) and tiles on top, or a "bermuda" stucco roof applicaton with high reflective elastomeric paint as a waterproofing. Remember this system also have 4 1/2" of EPS below from 1.5 pounds per cubic foot to 3 pound resulting in more R-value and no beams in the middle.
Regards,
Raul
People Online People Online: Visitors Visitors: 146 Members Members: 0 Total Total: 146
