Posted By ICFDude on 04/18/2009 3:30 AM
Mark,
So are you attaching doors and windows like Introspec recomends? with a lil peice of plywood screwed to the window? then what do you screw that to? the webs on the block out blocking?
Denny
PS nice clean job, may try this some time
No wood:
check ICC, 144 lbs per screw each tie, then use enerbond (not enerfoam) rated at 40 PSI, to fill, which is also structurally rated, resulting in a window, you cant take out from the outside, you have to do so only from the inside, although you still remove it by pushing it out to the exterior, you cannot take it out from the interior.
BTW had a client that did not believe me on this, made him a bet that he could not remove the window in one piece without cutting the enerbond. Window was destroyed, frame never came out, however cut it out in 2 minutes from the inside. Works great.
