New home
Last Post 26 Apr 2009 05:14 AM by Hoowood. 2 Replies.
billpxtnUser is Offline
25 Apr 2009 05:23 PM
Hello,everyone this is my first post but I have had a long time interest in constructing a home using ICF.We are going to build on a property we own near Herman NE.It will be a 2 story with a octagon lighthouse effect to one side.We have been looking at rewards system as they are close to us in Omaha.We have not settled on a contractor yet and are looking for reccomendations.Is there anyone out familiar with someone in our area?
buddenUser is Offline
26 Apr 2009 12:44 AM
Fox Blocks is also in Omaha; Lite-form is in South Sioux City
HoowoodUser is Offline
Hello Billpxtn
It really doesn´t matter to ask what or whom you gonna choose. The point is that you have to collect the data and sources for YOUR HOME. Only when you are convinced that you have the best found you should start the specific plannings. It is your money you invest and your headache you get. So be carful, read a lot and don´t miss chances to get knowledge. ´Spend time in DD and reading, start collectig informations, check prices $/sf and find out what is available in your area. Always take a chance for a 2nd opinion. I will give you an example what you need to think of besides the costs for everything before you start building. Whenever you have these costs based on the house and its sq ft numbers double check with your bank to not have a nightmare when let´s say you invest $300,000 and by the end of the thday the bank sneds his appraiser and the value is only $250,000. Check the forum read over the headlines and click the important once. Good luck and alway come back in here
Excavation
Foundation, Piers, Flatwork
Interior Frame walls,sub floor
Masonry Frame
Concrete ? yard
Exterior Trim,Sofia & Porch
Roof & Insulation
Doors
Windows
Finish Hardware
Garage Door
Roofing, Flashing, Fascia
Finish Carpentry
Interior Wall Finish
Painting
Wiring
Lighting Fixtures
Hardwood Flooring
Carpeting
Bath Accessories
Shower & Tub Enclosure
Countertops
Cabinets
Built In Appliances
Plumbing Rough & Finish
Plumbing Fixtures
Airing System
Unit Cooling Garage
Exterior Stucco
Final Cleanup
Insurance
Permits & Utilities
Plans & Specs
People Online People Online: Visitors Visitors: 201 Members Members: 0 Total Total: 201
