ICF rafter ties
Last Post 05 May 2009 08:07 PM by ICFconstruction. 4 Replies.
biglumber35User is Offline
03 May 2009 05:35 PM
Hi All
Helping a friend who will be building a full ICF home. I was wondering what system is used to secure the trusses to the exteriror walls. I know of a sill and toe nailing. Does anyone use a specific Simpson Strong-Tie Rafter Tie of some sort. Also is it installed during the concrete pour or post installation.
model # and any help would be great
__________
that is how I see it on my side of the fence
03 May 2009 07:01 PM
Try Simpson 'TSS'
Wet set or set in place before placing concrete
03 May 2009 09:42 PM
Ideally, the wood truss should not be in direct contact with the concrete.  I believe treated lumber or a piece of galvanized metal should be used between the truss and the concrete wall unless the metal fastening clip makes the separation.  Toe-nailing a wood truss can weaken the bottom chord.
FarmboyUser is Offline
05 May 2009 10:45 AM
Here's a truss tie we're considering for our home in Kansas due to the winds we experience.  We plan to wet set them after carefully marking locations.  They will handle the uplift and eliminate wood to concrete contact.
http://www.strongtie.com/products/connectors/META-HETA-HHETA-HETAL-DETAL-TSS.asp
ICF connect can also be used as a hurricane clip.
People Online People Online: Visitors Visitors: 172 Members Members: 0 Total Total: 172
