TF ICF panels - Below grade waterproofing
Last Post 31 Jul 2009 07:07 AM by smartwall. 23 Replies.
08 Jun 2009 05:38 AM
Newbiejohn,
The link to Miradri and Miradrain is
www.carlisle-ccw.com.
arkie6User is Offline
08 Jun 2009 06:27 AM
My ICF distributer/builder uses and recommends TAMKO TW-60 sheet waterproofing membrane along with their mastic for sealing all joints and edges.
TAMKO TW-60 link
TAMKO TMW-1 Mastic link
Enter your zip code in the block provided at the top of each page to find your closest distributer/dealer.
tsr966User is Offline
30 Jul 2009 12:57 PM
What would be the best products to use if you have to excavate and install for an existing basement with ICF's? I will use a dimple board but what waterproofing will work the best under the dimple board if the ICF's are dirty and have some moisture it them?
smartwallUser is Offline
I had to do a remediation job on a botched peel and stick over icf's. We used a pressure washer to clean the dirt off then a electic leaf blower to dry the surface. Fixed the bad seams on the peel and stick then hung DMX over the top. That was three years ago and no problem.
People Online People Online: Visitors Visitors: 417 Members Members: 0 Total Total: 417
